De Que Son Estos Fallos??? - .:SoloVag:.
Mensajepor borja_perez » Jue Feb 26, 2009 1:32 pm
Los del modulo confort del espejo me lo se, la duda es la que dice de la llave...que no tengo ni idea y los del navegador y la radio tampoco tengo ni idea
Copio aqui los fallos
VAG-COM Version: Release 311.2-N
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01 -------------------------------------------------------
Controller: 038 906 012 M
Component: 1,9l R4 EDC 0400SG 2813
Coding: 00002
Shop #: WSC 01317
3 Faults Found:
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 35-10 - - - Intermittent
17946 - Fuel Shutoff Solenoid (N109): Open or Short to Ground
P1538 - 35-10 - - - Intermittent
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-10 - - - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 1C0 907 379
Component: ESP 20 CAN V005
Coding: 18945
Shop #: WSC 01317
No fault code found.
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 1J5 920 826 C
Component: KOMBI+WEGFAHRSP VDO V13
Coding: 05102
Shop #: WSC 00046
WVWZZZ1JZ3B060227 VWZ7Z0B6077782
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Coding: 00006
Shop #: WSC 00046
Address 46 -------------------------------------------------------
Controller: 1J0 959 799 AH
Component: 4H Zentral-SG Komf. 0001
Coding: 00257
Shop #: WSC 01317
4 Faults Found:
00849 - S-contact at Ignition/Starter Switch (D)
25-00 - Unknown Switch Condition
00953 - Interior Light Time limit
25-10 - Unknown Switch Condition - Intermittent
00943 - Heated Exterior Mirror: Driver Side (Z4)
35-00 - -
00913 - Window Regulator Switch: Front Right Driver (E81)
27-10 - Implausible Signal - Intermittent
Address 56 -------------------------------------------------------
Controller: 3B0 035 186 D
Component: Radio BNO 0304
Coding: 00401
Shop #: WSC 00571
3 Faults Found:
36-00 - Open Circuit
00856 - Radio Antenna
00853 - Loudspeaker(s): Rear
End -------------------------------------------------------
Control Module Part Number: 3B0 000 000 E
Component and/or Version: Navigation BNO 0304
Software Coding: 00002
Work Shop Code: WSC 00000
4 Faults Found:
00625 - Vehicle Speed Signal
03-00 - No Signal
00867 - Connection to ABS Control Module
03-00 - No Signal
65535 - Internal Control Module Memory Error
00-00 - -
00481 - Control Module for Traffic Radio (J559)
49-00 - No Communications
Re: De Que Son Estos Fallos???
Mensajepor madelgado » Jue Feb 26, 2009 2:47 pm
ahora que tienes una copia impresa de los errores, yo los borraría todos y daría unas vueltas con el coche para ver los que vuelven a aparecer...
Por lo pronto, hay algo en la puerta del conductor, en el cableado del confort y en el navegador... ¿has modificado bits del confort?
Mensajepor borja_perez » Jue Feb 26, 2009 11:17 pm
Usuarios navegando por este Foro: No hay usuarios registrados visitando el Foro y 27 invitados
